Bit stopping midway through a cut
Hi. I’m trying to make cutting boards, and my bit on the second cut screams, and stops. I’m using white oak .8 inch deep. secondly is there a users manual to guide one through this?
We walk through this sort of thing at:
https://my.carbide3d.com/#Projects
Did you install your BitSetter and configure it when setting up your machine?
https://carbide3d.com/hub/docs/shapeoko-setup/
https://carbide3d.com/hub/courses/running-shapeoko/configuring-bitsetter/
For Carbide Motion I wrote up a bit at:
and for Carbide Create:
Thank you. I’ll go through that first.
.8” cut in a single pass??
That seems like a big bite in white oak. What size router, spindle?
No, I was doing it in increments.
Did you get your issue resolved?
No the weather down here has been bad, Dune leavel sandstorms, been stuck inside all week.
