It’s been a couple of years since I installed it. Usually the big flash eaters are the COREXY and PARKING options. The latter is standard on Carbide machines, I think. I would say that there is a small chance it could fit without COREXY.
@MarkLince, @neilferreri, it seems like the universe (well, Sonny) is telling us that one of us should try it
Of course.
Its difficult to be vigilant if your’re absent!
it would be very interesting
Ok, just because it sounded like a fun week-end challenge, I had a go at this and merged the SLEEP mode from Grbl-Mega into Grbl, and adapted it to the ATMega328.
Since all timers are already used in the code (the three timers and one watchdog timer), I had to sacrifice something. The three timers are used to control the stepper and PWM signals, so that’s a no-no. I noticed that the watchdog timer is used only for the optional “software debouncing” of the limit switches, which is not enabled in the Shapeoko firmware anyway, so that’s what I hacked.
Luckily the added code fit in the memory when using the Shapeoko configuration, 176bytes short of the 32256 bytes limit. Phew.
Anyway, here’s a first test using that patched firmware, and pulling the USB cable while the spindle (and shopvac…) are running, with SLEEP mode enable and a 5 seconds timeout value
(warning: turn volume down)
The spindle stops and the machine parks upon pulling the cable.
So it works fine when using Carbide Motion (which does send a continuous stream of status queries to the controller, keeping the firmware alive), but that’s when I realized that CNCjs does not, which is a problem for me since I use both (and I don’t feel like patching CNCjs to send commands continuously), so I guess this will remain a fun experiment for now.
This is fantastic well done @Julien. If its doable then I think it should be considered by carbide3d as an important safety update to the system. I’m fitting my replacement board today/ tomorrow so I think this is a must do, especially when using the BitRunner. Again well done. See I said it should be possible, even though I had no idea how I’m going to need to pick your brains to get this into my new board.
