Bitrunner stopped
I was standing in front of my pro xl when the router turned on unexpectedly. I tried to turn it off and I couldnt. So unpluged the butrunner, checked the fuse, checked all connections, its has power to it, however when i try to run a file with shapeako ATC post processor it won’t turn the router on.
Hopefully someone else gas had this issue and resolved it.
Thank you,
Tim J Taylor
Please let us know about this at support@carbide3d.com and we will do our best to assist.
I did what all cnc’ers should do…I shut everything down, restarted my computer, un-installed carbide ATC PP, re-loaded as my ATC PP and voila did a air cut and it worked. Now my machine is in the process of cutting a beautiful bald eagle.
Thank you Will for offering support so quickly.
Tim
