BitRunner V2 CMB613 Cannot configure
Recently installed the BitRunner V2 and currently running Carbide Motion B613. I cannot get to the part in the settings to enable it. Please Advise. Thanks!
In the v6 series I believe enabling the BitRunner initially is done in the Setup Wizard.
If you haven’t already, please contact us at support@carbide3d.com and we will walk through this with you.
Thanks for the quick reply! I went back into the setup wizard and was able to connect the BitRunner! Worked perfect! Thanks again…Make it a great day!!
