Bitrunner V2 Fuse Type
Hey everyone, I need to replace the 15A, 250v 5 x 20mm fuse and was curious if it should be a slow or fast blow fuse. Could someone recommend a replacement fuse? I can’t locate these locally so I’ll likely order from Amazons.
Is there a marking like “T”, “F”, “M”?
I had a hard time deciphering, but will take a look. I used the dimensions found in the bit runner manual to order replacements - which worked.
Thanks for the information!
