BitRunner V2 worked for a couple months (and last night), not working this morning
Hello,
I’ve had my Bitrunner V2 for a little while now and it’s been working great. I’ve got my Carbide Router and shopvac hooked up to it. I was cutting last night and everything was working fine. I start working this morning and when I started up my project the router and shopvac didn’t turn on. Confused, I turned everything off, reinitialized the cnc, no luck. The yellow LED is on where the ethernet cable connects, the red light on the “spindle enable” is also on, but nothing is turning on. I disconnected and reconnected all the cables. Nothing. What could be wrong? The machine I have is a Shapeoko Pro XXL if this helps.
Did you contact support@carbide3d.com ?
It may be the fuse that’s in the BitRunner that’s blown, or some wiring issue and the BitRunner is not picking up the PWM signal from the controller anymore.
Support is your best bet in any case
