Bitrunner (V3?)
I’m looking at the Bitrunner v2, being in the UK or indeed the EU requires either adaptors or cutting off cables. I’d like to make a suggestion/feature request for the Bitrunner V3.
Use an IEC connector for the router side. (IEC to socket can be found for use with a UPS’s, for example)
Use a C5 connector for the mains side. (C5 to plug can be found for many, many PSU’s etc)
This would allow anyone in any country with supported voltages to simply source the cables locally and cheaply with no potential risks and also pass through the earthing wire.
Obviously using different connectors to follow the ethos of only being able to plug the cable into the correct socket.
