Bitrunner works on one computer, not the other
I changed laptop in the workshop and set up the Shapeoko Pro again with no issues. When I came to run a job the router never starts but Carbid Motion doesn’t show any errors and would go ahead and try to run without the router started.
If I connect the previous laptop, and make not other changes at all, the router starts. So it’s entirely to do with the Carbide Motion software. As there are no settings anywhere for Bitrunner, I can’t think what’s going on. Can anyone help?
Check your settings again. I would think that you are not telling Carbide Motion that the BitRunner is installed. There is definitely a setting for BitRunner. Good Luck.
There are no settings in Carbide Motion for Bitrunner.
However, I noticed this in the “Machine settings” in CM:
"bitRunnerEnabled": false,
Configuration for a BitRunner (or VFD spindle) is done in the Setup Wizard:
https://carbide3d.com/hub/docs/shapeoko-setup/
Once one or the other has been configured for, it will be possible to enable/disable it. If which device is connected is changed it will be necessary to re-run the Setup Wizard.
