I have a shapeoko pro XXL currently and am in the process of finalising purchase of an upgrade to the shapeoko 5 with C3D’s 80mm vfd.
It occurred to me:
My Makita Router power plug connects to my Makita Vacuum - I run vacuum at lowest vacuum setting for quietness and it has a power tool plug integrated into the vacuum ).
The vacuum then connects to my bitrunner (to auto turn on-off both my router and vacuum simultaneously).
The bit runner then connects to a wall power outlet
Question:
Am I going to be able to continue to have this arrangement I bulleted out above if the only thing I did was swap out the router for the 80mm VFD, or can’t bitrunner deal with this 1 change considering it’s via my vacuum (so I will always have to manually turn on-off the vacuum from now on)?
I want to confirm since the article seems to be more generic to people who have a vacuum that does NOT have a tool attachment plug socket on it (see it’s diagram), so therefore they need this device as using a Bitrunner would only allow them to connect & auto-on/off only one or the other (router/spindle or vacuum).
The Auto-Vacuum Switch your article mentions runs the connections in a parallel configuration with 2 separate plugs on it to connect each separately:
VFD/router → Auto-Vacuum Switch +
Vacuum → Auto-Vacuum Switch
But my setup essentially does this same thing but in a series configuration:
(VFD/router → Vacuum → BitRunner)
My Bitrunner presumably is still working with this combination coz I have the vacuum on its lowest vacuum speed (so it has a low power draw), and my makita never really going above 18k rpm (so a low-moderate power draw).
Is this you confirming the BitRunner-v2(Deluxe) won’t work in the arrangement I currently have working with my router above, specifically because a VFD spindle is involved? Or was there a miscommunication between us about the nature of the setup and it would work just the same, in fact?
I will do what you mention but just to confirm for sure as this decides if I get rid of it with my old Pro XXL or keep it.
so I can’t speak to this beyond providing the link — if further information is needed, hopefully someone who uses such a unit can chime in, or you can check in w/ the folks at support.
