I’m having a problem using the bitsetter while connected to the probe adaptor. It just plunges down and keeps going, smashing my bit into it. If I unplug the adapter and plug the bitsetter directly into the reserved plug it works as it should. I have the bit zero and need to use it too but if the adaptor is used to connect both it isn’t working. Any ideas?
Please write in to support@carbide3d.com — I suspect you have a bad PCB adapter.
Well I actually ordered 2 bitsetters, so I took the adaptor out of that one and it’s the same result, I also just emailed into support
If you push on the button does the red light come on? If no red light the BitSetter is not triggered.
Yes, the red light comes on when I press it down
Can you get a pic of the adapter and its connectors?
