I have a Shapeoko 4 Std. I purchased a Bitsetter 3 in error…vs Bitsetter 4 when placing my order…
Questions are:
- Can either Bitsetter run on the Shapeoko 4 Std?
2)when creating the machine settings…using the Bitsetter 3 which do I select…BitZero V1 or V2…or is Bitzero not related to the Bitsetter?
3)if BitZero is unrelated to Bitsetter… which version should be used on the Shapeoko 4?
4)For the Bitsetter are there other settings that need to be changed/modified etc. beyond what is noted in Carbide Motion software?
Cheers
