Hey Guys,
I installed the Bitsetter and checked the right position in CarbideMotion(Build513).
When I initialize the machine the spindle also alignes perfect in X/Y-Direction with the Bitsetter. As the spindle goes down it crashes in the Bitsetter-Probe-Surface and won’t stop to step in Z-direction. The red indicatorlight does not light up, as the tool touches the probe. I double checked the wiring and use the Bitsetter without Touchprobe and Signal-Splitter.
What are your thoughts on this problem or did anybody have the same crashes?
Thanks, Max
With power on to the Shapeoko, can you manually push the bitsetter button and see the red light come on?
