Bit Setter was working flawlessly yesterday, but today it seemed to need a day off. When I initialize, it tries to set the bit length, go’s to the point above the bit setter, drops about an inch and stops. Eventually it throughs an error message saying that the cycle failed. I looked for anything that might be interfering with travel and nothing. As I said it worked flawlessly yesterday, so I don’t think it’s a catastrophe, and fortunately the job I’m on right now does not require a bit change, but I still need to figure out what’s going on.
Yes I have a Bitzero, but the problem is with the BitSetter. Do I need the ground lead of the BitZero grounded to use the BitSetter? I figured the BitSetter was grounded internally, but what do I know?
