I’m having issues with the bitsetter after initialization. After tool is selected the machine moves to bitsetter but jams once bit touches. Any help would be greatly appreciated.
Hi @Jorge73,
Does the red light come up when the endmill pushes the BitSetter button ? Does it light up when you press the BitSetter button manually ?
If not, this is likely a wiring issue between the BitSetter and the controller board.
Also, do you have Bitsetter set up properly in settings. It isn’t automatic, you have to choose your machine etc.
