I received a bitsetter and although works, seems to produce problems with tool changes, and repeating the job.
If I run a job, the bitsetter probes the tool #1 upon machine initialization, then I can use the xzy probe to locate the stock on the wasteboard, run the job, tool change partway through the job to tool #2 (which bitsetter probes tool length correctly) then after the job completes, tool #1 is placed back in the spindle to run the job again.
This is where the problem lies. I locate the stock on the wasteboard again with the xzy probe, Run the job (same job), bitsetter probes the tool, but since it was put back in the spindle at a different depth (after job #1 completed) it’s either too low or too high from the stock that was just probed with the xzy probe.
Make sense?, and is this intended functionality? I can reproduce this every time, so the temp solution is to switch off the control board to force the machine to prompt for initialization again, then everything is fine.
