Has anyone else had issues with the bitzero NOT fitting in the controller enclosure? I hook it into the bitzero plug on the board, but the rigid part of the connector extends past the enclosure. It can’t be bent, as I don’t want to put pressure on the controller board connection.
You may be able to trim back the heat shrink a little too relieve the strain. I think mine was a tight fit, but I just went with it. There isn’t movement in there, so it won’t fatigue anything.
