Hey folks! I’m using the Triquetra CNC touch probe (have also experienced this with the Dog River touch probe), and every time I use it to set the Z height, the Z is 0.5mm above the material. If I go to manually jog the spindle and drop to 0.25mm steps, it’s exactly two steps down in order to make a piece of paper not move underneath the bit. I’ve seen a few other threads out there but none were exactly this problem, so I wanted to see if anyone knew of a way to change the offset of the probe within Motion so that way I could just add the extra 0.5mm to the parameters and (hopefully) fix the problem? It seems to be exactly 0.5mm every time, and I would love to be able to use my touch probe to set zero instead of manually doing it every time.
I do wish I had an official BitZero to try out but alas it didn’t come with the CNC when I purchased it second-hand and I’ve got the other two touch probes on hand.
