Two backlog requests…
Let us pick the type of BitZero in settings (v1 or v2) so we don’t have to pick every time.
Use case for metal : I can actualyl just set the base of the V2 upside down, such that it makes contact with the metal surface. I can then zero the bit directly off my workpiece. This is useful for smaller workpieces that are challenging to either put the V2 on, or have it steady, and require using fingers to hold it straight on the 2 raised edges… I prefer keeping my fingers away
Likely, an option during zero to support this and avoid a trip to settings, but otherwise a settings option for “Z-probe thickness” that could be set to either the V2 thickness, or to zero in the case of a direct probe.
