Bitzero Plugged in
Hello All- Question regarding Bitzero. Is it ok to leave plugged in all the time? I can’t see removing the protective cover on the computer board each time I go to use it. Thanks.
As long as you don’t plan tripping on it.
I have never unplugged mine.
Excellent. Thank you.
Just make sure the lead with the magnet isn’t touching the body of the BitZero.
As @mhotchin said dont let the magnet touch the BitZero or get grounded to the machine. I made a holder to keep my BitZero in and just wrap the two cables around the holder to keep from making a trip hazard. I let the magnet dangle over the side so it does not touch the BitZero or the frame of the Shapeoko.
Will do. Thank you very much
Thanks Mike. Appreciate it.
