Having problems diagnosing my issues here. I have Shapeoko3 XXL, belt drive, bit zero V1, and Bitsetter.
When I try and zero with the probe, I get an error. “Probe Failed” Then I need to reinitialize the machine. Same happens with the Bitsetter, though the Bitsetter does move down a bit before the error occurs.
I have manual zero’d the machine and a couple of times the machine will stop and act as though it has been disconnected. I have updated my softwares and checked all connections. Any help would be appreciated! Thanks!
When you first power up and connect what shows under “Active Inputs” on the Settings pane? -not 100% where to find this. I did however see that the bitzero was connected?
Where are the BitZero v1 and ground lead stored? Are they touching? -I do not think they are but here is a picture of where they are connected. This gave me an idea and I did unplug the bitsetter and was able to probe. The machine is currently running. Fingers crossed that it completes the operation.
