My new procedure? or the way i did it with the bitzero v2? bitzero v2 way was step by step from what the instructions said. probing off lower left corner.
My new way i just cad up a corner piece with a 1/8th hole right in the corner and made edges on the bottom just like the bitzero v2 so i could square it up. Then i 3d printed the part. i can send you the file if needed. Pretty simple jig.
I was having weird bitzero issues last fall, the problem ended up being a loose drag chain (that wasn’t immediately obvious) that was causing a bit of resistance during the probe.
