So I bought my HDM a couple months ago, but I’ve barely had a chance to play with it. At first i thought it was user error, but now I’m beginning to think something is wrong with the machine.
I first noticed an issue trying to go through a sinple v carve tutorial. The bit would either not touch the material or plunge way too far. I eventually moved onto fusion only to have more z height issues, but again, I thought I must be doing something wrong.
Now I feel pretty confident my bitsetter is not functioning as it should. I absolutely cannot get consistent results after it probes a tool.
A few moments ago I turned the machine on, initialized it, manually clicked on the tool change button in Carbide Motion and inserted a tool. I zeroed it on a work piece, then hit the tool change button again, but I left the tool alone. Didnt even touch it. I just let it go through the tool probe procedure, and when i brought it back to zero Z height, it was offset by about 2mm. X and Y were fine.
Has anyone experienced anything similar? Any tips?
