When saving gcode in Carbide Create, there is no file extension appended to the gcode file whatsoever.
Impact: Carbide Motion will not be able to open the file.
Workaround: The user must remember to add “.nc” to the filename whenever saving the gcode.
Regression: This issue was NOT seen in build 474. “.nc” was appended to the filename even when the user did not specify.
Test Environment:
- MacOS 10.15.7
- Carbide Create build 514
