I found a bug in CC Pro while using my 14-day trial. When I import a second greyscale PNG to create a topographic model to replace the original image, CC Pro immediately crashes unless I first change the resolution of the project. I can change it from high to very high and it works. I can also change it from very high down to high and it works. However, if I leave the resolution setting and try to import another image, it always crashes.
Is this the best way to report a bug, or should I email support?
