Requires BitSetter enabled. This is on a Raspberry Pi, unsure if Windows is the same.
- Run a job
- As soon as you are prompted to insert tool XXX, hit RESUME. This must be done quickly.
- It should have a similar action as “stay paused”. So it will go to the run menu, you will have to hit resume, and then it will execute the probe.
At first I thought I needed more coffee
But had it happen a few times. Typically for jobs I will already have the first bit loaded so I’m very quick to hit resume for that first tool change.
