Can I do this (and not regret it later)?
I wish to create a rectangle with internal radius’ed corners using a V-cutter, by the way I am using Vcarve desktop. From what I can see a V-cutter will not follow a single line toolpath but needs a ‘channel’ to follow. If I create this ‘channel’ in Vcarve desktop it isn’t possible to keep the radius’ed corners a constant width:
Now the question: can I define the toolpath as a profile cut using a single line but use a V-cutter in the spindle. The depth of cut would have to be carefully adjusted but it seems a reasonable assumption that this should be possible. Or will I regret it after or during the action?
A follow path w/ a V-bit to a reasonable depth should be fine.
Thanks Will, that’s what I suspected.
To be clear, you are cutting through the material first, last or is the v-cutter doing that? You can use most cutters for line following in an outside corner.
The traditional advantage to the v-carve path is the sharp inside corners it can make. This doesn’t seem to have them - you simply want an outside bevel around the board. A following a line should be fine.
Try to create an inside offset of 2mm from your outside vector with sharp corners. That should maintain equal distance.
If you select the V-bit to follow a line, you will not get sharp outside corners.
Biologyben Ben
No Ben, the V-cutter is doing all the cutting
Lewscrew Craig
Yes I had forgotten the rounded outside corners, thanks Craig. I’ll see how it all goes
FWIW, it’d be easy enough to get accurate geometry for this in any drawing program — just draw the centerline, set it to a 2mm stroke, then expand the stroke.
VCarve has an “Offset selected vectors” action (first icon in the Offset and Layout section, looks like a blue square surrounded by a dashed red line). This should keep the constant width around your inner shape.
Thank you chaunax so easy when one knows how. I am pretty new to CNC and very new to Vcarve. This Vcarve is an excellent application I love it already and I only know a small percentage of its capabilities. Incidentally the project has worked out well. Thanks to all for your help.
