I have an application where we’d like to try using a needle to perforate a specific pattern of holes into a soft material. A thick felt.
I have the collet for securing a 1mm diameter needle, and I will run program as if the needle was a drill bit, but we’d also like to see what happens if the needle isn’t spinning. Just pecking through.
Can I set spindle speed to zero? Or, is the only way to do it to remove belts from spindle motor? Would removing belts cause undo stress on spindle motor since there’s no resistance?
What’s the best work around here?
Open up the generated G-code in a text editor (e.g. Notepad) and look for a line like M3 S1 and remove it.
The G-code file is a list of instructions telling the machine what to do to make your part. M3 means “turn on the spindle” and “S1” means “with the speed set to 1 RPM”. Removing that line means the machine is never told to turn the spindle on, so it won’t.
FYI - on the Nomad3 with the newest releases of “Carbide Create” (build 530) - setting spindle rpm to “1” basically turns off the spindle. I did not have to manipulate gcode at all.
