Hello I’m new whit this technology, I’m looking for a software for laser cutting and I found thisone that looks very nice but I want to know if I can use Carbide Create whit other kinds of machines ?
Thanks
Thanks
Yes, Carbide Create outputs fairly basic G-Code — it’s just a matter of mapping the tool changes, feed rates, cutting depths, and safety height to something which works with the machine — it may be necessary to do some post-processing/editing.
Thanks!
So Can I connect directly my laptop to any laser cutter machine using Carbide Create or Carbide motions?
Thanks again
Using Carbide Create you can create a file which can be sent to pretty much any machine which understands the G-Code which it makes.
Carbide Motion is specific to Carbide 3D machines and won’t work with other devices.
