Just got the shapeoko 4 xxl. I’m trying to set my bit setter but when I try to jog it says busy. The rapid position works but not the manual jog. Can anybody help?
When you jog, are you increasing the increment from the default tiny/imperceptible 0.01mm?
What happens if you set it to Fast?
Yes, that worked. Thank you so much
Not sure which is worse. The tiny increment as default or fast as default. May a happy medium could be set as default by developers. IMO.
