Can't change center of rotation with mouse?
The manual says “The rotate too will allow you to rotate selected vector paths. This tool is
extremely versatile as you can change the center of rotation using the X or Y fields if needed. If using this tool artistically you can move the center of rotation with your mouse.
It does let me drag the center, but it just jumps back after releasing the mouse button. I have tried with modifier keys as well. What am I missing?
center
Same. Only works if you type in the numbers. “Artistically??”
Previously discussed at:
this has been noted as a bug.
