kdur
(Kim Durabb)
May 23, 2017, 12:53pm
#1
Hi, I’m a complete newbie and have had my machine less than a week. The problem I’m having is as follows:
Actual stock thickness is .25" nickel silver. Trying to cut 2 simple circles in CC. I’ve had to change stock thickness to .30" and max depth to .38". Still leaving a skin. I’ve zeroed x, y, z. Using a .0625 square cutter. Speeds set automatically although I did change Depth per pass from .008 to .010 (thought it would help the cutter go deeper). Other settings are stepover=.028, feed=12.3, plunge=1.537, rpm=9000.
What am I doing wrong? Why won’t it cut through the stock?
Thanks,
Kim
Kim, we will need more information to answer that.
Please post your CC file and GCode file as well as a setup sketch showing us your X0, Y0 and Z0 as well as telling us how you are setting your 0,0,0.
If I am speaking a strange language, please feel free to say so.
kdur
(Kim Durabb)
May 23, 2017, 1:33pm
#3
Ok, great! Thank you so much! I’ve attached both the CC file and the gcode file along with a photo of the 2 circles. I send the file to CM from CC, then I go to jog, then put both x and y at the bottom left corner of my stock. Then I drop z until I feel the drag on a sheet of paper. After that I zero out all 3 and click run.
Let me know if you need anything else.
Thanks,
Kimcircles.c2d (4.3 KB)
circles.egc (27.3 KB)
I have 1 silly question, and 2 smart one:
How thick is your feeler gauge?
Do you account for it? (Lower the Z that feeler gauge distance)
Before I look at the CC file, where do you set you Z0 in CC (Top/bottom)?
One request: Do you know how to post your GCode in a text format? Because I can’t look at the EGC file unless I am hooked up to my machine (and I’m sitting on my couch), and I’d really like to read your CGode. If not please feel free to ask.
kdur
(Kim Durabb)
May 23, 2017, 1:40pm
#5
The feeler gauge is paper thin. I used a #2 on a feeler gauge that corresponds to a sheet of thin paper if that makes sense. I lowered the Z until I feel a slight drag. Z0 set for top.
kdur
(Kim Durabb)
May 23, 2017, 1:47pm
#6
Hope this is right.
(FILENAME: )
G21
G90
G0X0.000Y0.000Z2.000
(TOOL/MILL,1.5875,0,1.0000,0.0)
M6 T112
M3 S9000
G0X8.018Y9.814
G0
G1Z-0.254F39.0
G1X8.232Y9.609F312.4
X8.655Y9.228
X9.087Y8.871
X9.534Y8.531
X9.774Y8.361
X10.242Y8.051
X10.711Y7.767
X10.959Y7.627
X11.456Y7.366
X11.969Y7.126
X12.243Y7.007
X12.750Y6.806
X13.301Y6.614
X13.578Y6.528
X14.091Y6.385
X14.657Y6.251
X15.204Y6.147
X15.780Y6.062
X16.329Y6.005
X16.620Y5.983
X17.176Y5.960
X17.476Y5.957
X18.036Y5.969
X18.583Y6.004
X19.142Y6.062
X19.448Y6.104
X19.978Y6.194
X20.523Y6.309
X21.080Y6.452
X21.368Y6.536
X21.896Y6.707
X22.426Y6.904
X22.937Y7.119
X23.450Y7.359
X23.971Y7.632
X24.443Y7.905
X24.682Y8.053
X25.167Y8.375
X25.610Y8.698
X26.063Y9.056
X26.281Y9.241
X26.701Y9.619
X27.101Y10.011
X27.297Y10.216
X27.665Y10.624
X28.021Y11.054
X28.213Y11.301
X28.544Y11.758
X28.845Y12.212
X29.147Y12.710
X29.406Y13.182
X29.538Y13.440
X29.784Y13.962
X30.004Y14.486
X30.194Y14.998
X30.286Y15.270
X30.454Y15.824
X30.592Y16.364
X30.711Y16.923
X30.761Y17.203
X30.841Y17.748
X30.902Y18.324
X30.936Y18.870
X30.946Y19.159
Y19.728
X30.936Y20.020
X30.902Y20.565
X30.842Y21.135
X30.760Y21.693
X30.711Y21.967
X30.592Y22.526
X30.526Y22.797
X30.373Y23.345
X30.198Y23.881
X30.000Y24.414
X29.789Y24.916
X29.538Y25.450
X29.412Y25.697
X29.143Y26.187
X28.852Y26.667
X28.540Y27.138
X28.203Y27.602
X28.020Y27.837
X27.665Y28.265
X27.290Y28.682
X26.894Y29.085
X26.689Y29.281
X26.281Y29.649
X25.834Y30.019
X25.387Y30.359
X25.147Y30.529
X24.697Y30.827
X24.207Y31.124
X23.958Y31.265
X23.472Y31.519
X22.959Y31.761
X22.434Y31.983
X21.907Y32.179
X21.615Y32.277
X21.080Y32.438
X20.823Y32.507
X20.254Y32.641
X19.716Y32.743
X19.156Y32.826
X18.603Y32.884
X18.035Y32.921
X17.445Y32.933
X16.885Y32.921
X16.338Y32.886
X15.779Y32.828
X15.473Y32.786
X14.943Y32.696
X14.398Y32.581
X13.841Y32.438
X13.569Y32.359
X13.025Y32.183
X12.505Y31.990
X11.982Y31.771
X11.454Y31.522
X10.950Y31.258
X10.478Y30.985
X10.239Y30.837
X9.767Y30.524
X9.518Y30.347
X9.095Y30.025
X8.660Y29.666
X8.238Y29.288
X7.817Y28.876
X7.432Y28.466
X7.073Y28.048
X6.708Y27.589
X6.392Y27.153
X6.221Y26.903
X5.922Y26.429
X5.774Y26.180
X5.513Y25.705
X5.254Y25.183
X5.023Y24.664
X4.818Y24.145
X4.722Y23.878
X4.544Y23.331
X4.394Y22.792
X4.270Y22.262
X4.163Y21.706
X4.079Y21.135
X4.046Y20.854
X3.999Y20.286
X3.975Y19.731
Y19.162
X3.985Y18.870
X4.019Y18.325
X4.079Y17.755
X4.161Y17.197
X4.210Y16.923
X4.328Y16.368
X4.473Y15.803
X4.638Y15.261
X4.819Y14.742
X4.921Y14.476
X5.132Y13.974
X5.383Y13.440
X5.509Y13.193
X5.778Y12.703
X6.069Y12.223
X6.381Y11.752
X6.718Y11.288
X6.901Y11.053
X7.249Y10.633
X7.438Y10.417
X7.631Y10.208
X8.018Y9.814
G0Z2.000
G0
G0
G1Z-0.508F39.0
X8.655Y9.228
X9.087Y8.871
X9.534Y8.531
X9.774Y8.361
X10.242Y8.051
X10.711Y7.767
X10.959Y7.627
X11.456Y7.366
X11.969Y7.126
X12.243Y7.007
X12.750Y6.806
X13.301Y6.614
X13.578Y6.528
X14.091Y6.385
X14.657Y6.251
X15.204Y6.147
X15.780Y6.062
X16.329Y6.005
X16.620Y5.983
X17.176Y5.960
X17.476Y5.957
X18.036Y5.969
X18.583Y6.004
X19.142Y6.062
X19.448Y6.104
X19.978Y6.194
X20.523Y6.309
X21.080Y6.452
X21.368Y6.536
X21.896Y6.707
X22.426Y6.904
X22.937Y7.119
X23.450Y7.359
X23.971Y7.632
X24.443Y7.905
X24.682Y8.053
X25.167Y8.375
X25.610Y8.698
X26.063Y9.056
X26.281Y9.241
X26.701Y9.619
X27.101Y10.011
X27.297Y10.216
X27.665Y10.624
X28.021Y11.054
X28.213Y11.301
X28.544Y11.758
X28.845Y12.212
X29.147Y12.710
X29.406Y13.182
X29.538Y13.440
X29.784Y13.962
X30.004Y14.486
X30.194Y14.998
X30.286Y15.270
X30.454Y15.824
X30.592Y16.364
X30.711Y16.923
X30.761Y17.203
X30.841Y17.748
X30.902Y18.324
X30.936Y18.870
X30.946Y19.159
Y19.728
X30.936Y20.020
X30.902Y20.565
X30.842Y21.135
X30.760Y21.693
X30.711Y21.967
X30.592Y22.526
X30.526Y22.797
X30.373Y23.345
X30.198Y23.881
X30.000Y24.414
X29.789Y24.916
X29.538Y25.450
X29.412Y25.697
X29.143Y26.187
X28.852Y26.667
X28.540Y27.138
X28.203Y27.602
X28.020Y27.837
X27.665Y28.265
X27.290Y28.682
X26.894Y29.085
X26.689Y29.281
X26.281Y29.649
X25.834Y30.019
X25.387Y30.359
X25.147Y30.529
X24.697Y30.827
X24.207Y31.124
X23.958Y31.265
X23.472Y31.519
X22.959Y31.761
X22.434Y31.983
X21.907Y32.179
X21.615Y32.277
X21.080Y32.438
X20.823Y32.507
X20.254Y32.641
X19.716Y32.743
X19.156Y32.826
X18.603Y32.884
X18.035Y32.921
X17.445Y32.933
X16.885Y32.921
X16.338Y32.886
X15.779Y32.828
X15.473Y32.786
X14.943Y32.696
X14.398Y32.581
X13.841Y32.438
X13.569Y32.359
X13.025Y32.183
X12.505Y31.990
X11.982Y31.771
X11.454Y31.522
X10.950Y31.258
X10.478Y30.985
X10.239Y30.837
X9.767Y30.524
X9.518Y30.347
X9.095Y30.025
X8.660Y29.666
X8.238Y29.288
X7.817Y28.876
X7.432Y28.466
X7.073Y28.048
X6.708Y27.589
X6.392Y27.153
X6.221Y26.903
X5.922Y26.429
X5.774Y26.180
X5.513Y25.705
X5.254Y25.183
X5.023Y24.664
X4.818Y24.145
X4.722Y23.878
X4.544Y23.331
X4.394Y22.792
X4.270Y22.262
X4.163Y21.706
X4.079Y21.135
X4.046Y20.854
X3.999Y20.286
X3.975Y19.731
Y19.162
X3.985Y18.870
X4.019Y18.325
X4.079Y17.755
X4.161Y17.197
X4.210Y16.923
X4.328Y16.368
X4.473Y15.803
X4.638Y15.261
X4.819Y14.742
X4.921Y14.476
X5.132Y13.974
X5.383Y13.440
X5.509Y13.193
X5.778Y12.703
X6.069Y12.223
X6.381Y11.752
X6.718Y11.288
X6.901Y11.053
X7.249Y10.633
X7.438Y10.417
X7.631Y10.208
X8.018Y9.814
G0Z2.000
G0
G0
G1Z-0.711F39.0
X8.655Y9.228
X9.087Y8.871
X9.534Y8.531
X9.774Y8.361
X10.242Y8.051
X10.711Y7.767
X10.959Y7.627
X11.456Y7.366
X11.969Y7.126
X12.243Y7.007
X12.750Y6.806
X13.301Y6.614
X13.578Y6.528
X14.091Y6.385
X14.657Y6.251
X15.204Y6.147
X15.780Y6.062
X16.329Y6.005
X16.620Y5.983
X17.176Y5.960
X17.476Y5.957
X18.036Y5.969
X18.583Y6.004
X19.142Y6.062
X19.448Y6.104
X19.978Y6.194
X20.523Y6.309
X21.080Y6.452
X21.368Y6.536
X21.896Y6.707
X22.426Y6.904
X22.937Y7.119
X23.450Y7.359
X23.971Y7.632
X24.443Y7.905
X24.682Y8.053
X25.167Y8.375
X25.610Y8.698
X26.063Y9.056
X26.281Y9.241
X26.701Y9.619
X27.101Y10.011
X27.297Y10.216
X27.665Y10.624
X28.021Y11.054
X28.213Y11.301
X28.544Y11.758
X28.845Y12.212
X29.147Y12.710
X29.406Y13.182
X29.538Y13.440
X29.784Y13.962
X30.004Y14.486
X30.194Y14.998
X30.286Y15.270
X30.454Y15.824
X30.592Y16.364
X30.711Y16.923
X30.761Y17.203
X30.841Y17.748
X30.902Y18.324
X30.936Y18.870
X30.946Y19.159
Y19.728
X30.936Y20.020
X30.902Y20.565
X30.842Y21.135
X30.760Y21.693
X30.711Y21.967
X30.592Y22.526
X30.526Y22.797
X30.373Y23.345
X30.198Y23.881
X30.000Y24.414
X29.789Y24.916
X29.538Y25.450
X29.412Y25.697
X29.143Y26.187
X28.852Y26.667
X28.540Y27.138
X28.203Y27.602
X28.020Y27.837
X27.665Y28.265
X27.290Y28.682
X26.894Y29.085
X26.689Y29.281
X26.281Y29.649
X25.834Y30.019
X25.387Y30.359
X25.147Y30.529
X24.697Y30.827
X24.207Y31.124
X23.958Y31.265
X23.472Y31.519
X22.959Y31.761
X22.434Y31.983
X21.907Y32.179
X21.615Y32.277
X21.080Y32.438
X20.823Y32.507
X20.254Y32.641
X19.716Y32.743
X19.156Y32.826
X18.603Y32.884
X18.035Y32.921
X17.445Y32.933
X16.885Y32.921
X16.338Y32.886
X15.779Y32.828
X15.473Y32.786
X14.943Y32.696
X14.398Y32.581
X13.841Y32.438
X13.569Y32.359
X13.025Y32.183
X12.505Y31.990
X11.982Y31.771
X11.454Y31.522
X10.950Y31.258
X10.478Y30.985
X10.239Y30.837
X9.767Y30.524
X9.518Y30.347
X9.095Y30.025
X8.660Y29.666
X8.238Y29.288
X7.817Y28.876
X7.432Y28.466
X7.073Y28.048
X6.708Y27.589
X6.392Y27.153
X6.221Y26.903
X5.922Y26.429
X5.774Y26.180
X5.513Y25.705
X5.254Y25.183
X5.023Y24.664
X4.818Y24.145
X4.722Y23.878
X4.544Y23.331
X4.394Y22.792
X4.270Y22.262
X4.163Y21.706
X4.079Y21.135
X4.046Y20.854
X3.999Y20.286
X3.975Y19.731
Y19.162
X3.985Y18.870
X4.019Y18.325
X4.079Y17.755
X4.161Y17.197
X4.210Y16.923
X4.328Y16.368
X4.473Y15.803
X4.638Y15.261
X4.819Y14.742
X4.921Y14.476
X5.132Y13.974
X5.383Y13.440
X5.509Y13.193
X5.778Y12.703
X6.069Y12.223
X6.381Y11.752
X6.718Y11.288
X6.901Y11.053
X7.249Y10.633
X7.438Y10.417
X7.631Y10.208
X8.018Y9.814
G0Z2.000
G0X8.186Y42.363
G0
G1Z-0.254F39.0
G1X8.623Y41.935F312.4
X8.868Y41.710
X9.339Y41.304
X9.831Y40.914
X10.340Y40.543
X10.872Y40.190
X11.149Y40.018
X11.682Y39.711
X12.238Y39.420
X12.817Y39.147
X13.113Y39.019
X13.693Y38.790
X13.990Y38.682
X14.305Y38.577
X14.894Y38.399
X15.495Y38.244
X15.818Y38.172
X16.437Y38.054
X17.064Y37.961
X17.687Y37.896
X17.998Y37.873
X18.313Y37.856
X18.636Y37.846
X18.969Y37.843
X19.570Y37.855
X20.209Y37.895
X20.843Y37.961
X21.174Y38.007
X21.764Y38.107
X22.398Y38.241
X23.017Y38.400
X23.304Y38.483
X23.901Y38.677
X24.509Y38.903
X25.100Y39.152
X25.672Y39.422
X26.227Y39.712
X26.488Y39.859
X27.044Y40.196
X27.570Y40.546
X28.062Y40.904
X28.318Y41.102
X28.816Y41.514
X29.268Y41.920
X29.503Y42.145
X29.937Y42.589
X30.158Y42.828
X30.575Y43.311
X30.970Y43.809
X31.159Y44.065
X31.510Y44.569
X31.694Y44.852
X32.011Y45.376
X32.316Y45.930
X32.466Y46.225
X32.605Y46.513
X32.854Y47.073
X33.089Y47.667
X33.302Y48.277
X33.481Y48.870
X33.635Y49.468
X33.706Y49.787
X33.823Y50.398
X33.874Y50.719
X33.953Y51.343
X34.006Y51.969
X34.023Y52.285
X34.033Y52.608
X34.036Y52.942
X34.024Y53.542
X33.983Y54.192
X33.953Y54.509
X33.876Y55.120
X33.772Y55.736
X33.638Y56.370
X33.480Y56.985
X33.295Y57.595
X33.191Y57.902
X32.977Y58.477
X32.856Y58.773
X32.725Y59.074
X32.457Y59.644
X32.167Y60.199
X32.020Y60.460
X31.683Y61.016
X31.343Y61.528
X30.973Y62.038
X30.775Y62.292
X30.564Y62.553
X30.168Y63.012
X29.732Y63.476
X29.285Y63.915
X28.801Y64.350
X28.329Y64.740
X28.079Y64.934
X27.560Y65.312
X27.300Y65.489
X27.033Y65.661
X26.488Y65.992
X26.227Y66.139
X25.657Y66.437
X25.085Y66.706
X24.496Y66.953
X23.929Y67.164
X23.617Y67.269
X23.009Y67.453
X22.393Y67.611
X21.764Y67.744
X21.174Y67.844
X20.842Y67.890
X20.220Y67.955
X19.908Y67.978
X19.595Y67.995
X19.273Y68.005
X18.637
X18.313Y67.995
X17.998Y67.978
X17.689Y67.955
X17.071Y67.891
X16.437Y67.797
X15.822Y67.680
X15.508Y67.610
X14.894Y67.452
X14.599Y67.367
X14.005Y67.174
X13.397Y66.948
X12.808Y66.700
X12.254Y66.439
X11.956Y66.287
X11.404Y65.983
X11.134Y65.823
X10.609Y65.490
X10.336Y65.305
X9.841Y64.945
X9.346Y64.553
X8.856Y64.130
X8.407Y63.709
X7.963Y63.256
X7.738Y63.011
X7.338Y62.547
X7.129Y62.289
X6.752Y61.793
X6.396Y61.281
X6.050Y60.737
X5.885Y60.456
X5.592Y59.924
X5.301Y59.338
X5.052Y58.778
X4.926Y58.469
X4.712Y57.895
X4.510Y57.272
X4.346Y56.685
X4.200Y56.060
X4.082Y55.441
X3.990Y54.822
X3.954Y54.509
X3.901Y53.882
X3.884Y53.566
X3.870Y52.937
X3.884Y52.283
X3.923Y51.670
X3.989Y51.036
X4.035Y50.705
X4.138Y50.099
X4.266Y49.494
X4.344Y49.174
X4.510Y48.579
X4.715Y47.949
X4.929Y47.374
X5.049Y47.080
X5.307Y46.501
X5.585Y45.940
X5.893Y45.381
X6.211Y44.856
X6.387Y44.584
X6.747Y44.065
X7.127Y43.564
X7.336Y43.305
X7.749Y42.828
X8.186Y42.363
G0Z2.000
G0
G0
G1Z-0.508F39.0
X8.868Y41.710
X9.339Y41.304
X9.831Y40.914
X10.340Y40.543
X10.872Y40.190
X11.149Y40.018
X11.682Y39.711
X12.238Y39.420
X12.817Y39.147
X13.113Y39.019
X13.693Y38.790
X13.990Y38.682
X14.305Y38.577
X14.894Y38.399
X15.495Y38.244
X15.818Y38.172
X16.437Y38.054
X17.064Y37.961
X17.687Y37.896
X17.998Y37.873
X18.313Y37.856
X18.636Y37.846
X18.969Y37.843
X19.570Y37.855
X20.209Y37.895
X20.843Y37.961
X21.174Y38.007
X21.764Y38.107
X22.398Y38.241
X23.017Y38.400
X23.304Y38.483
X23.901Y38.677
X24.509Y38.903
X25.100Y39.152
X25.672Y39.422
X26.227Y39.712
X26.488Y39.859
X27.044Y40.196
X27.570Y40.546
X28.062Y40.904
X28.318Y41.102
X28.816Y41.514
X29.268Y41.920
X29.503Y42.145
X29.937Y42.589
X30.158Y42.828
X30.575Y43.311
X30.970Y43.809
X31.159Y44.065
X31.510Y44.569
X31.694Y44.852
X32.011Y45.376
X32.316Y45.930
X32.466Y46.225
X32.605Y46.513
X32.854Y47.073
X33.089Y47.667
X33.302Y48.277
X33.481Y48.870
X33.635Y49.468
X33.706Y49.787
X33.823Y50.398
X33.874Y50.719
X33.953Y51.343
X34.006Y51.969
X34.023Y52.285
X34.033Y52.608
X34.036Y52.942
X34.024Y53.542
X33.983Y54.192
X33.953Y54.509
X33.876Y55.120
X33.772Y55.736
X33.638Y56.370
X33.480Y56.985
X33.295Y57.595
X33.191Y57.902
X32.977Y58.477
X32.856Y58.773
X32.725Y59.074
X32.457Y59.644
X32.167Y60.199
X32.020Y60.460
X31.683Y61.016
X31.343Y61.528
X30.973Y62.038
X30.775Y62.292
X30.564Y62.553
X30.168Y63.012
X29.732Y63.476
X29.285Y63.915
X28.801Y64.350
X28.329Y64.740
X28.079Y64.934
X27.560Y65.312
X27.300Y65.489
X27.033Y65.661
X26.488Y65.992
X26.227Y66.139
X25.657Y66.437
X25.085Y66.706
X24.496Y66.953
X23.929Y67.164
X23.617Y67.269
X23.009Y67.453
X22.393Y67.611
X21.764Y67.744
X21.174Y67.844
X20.842Y67.890
X20.220Y67.955
X19.908Y67.978
X19.595Y67.995
X19.273Y68.005
X18.637
X18.313Y67.995
X17.998Y67.978
X17.689Y67.955
X17.071Y67.891
X16.437Y67.797
X15.822Y67.680
X15.508Y67.610
X14.894Y67.452
X14.599Y67.367
X14.005Y67.174
X13.397Y66.948
X12.808Y66.700
X12.254Y66.439
X11.956Y66.287
X11.404Y65.983
X11.134Y65.823
X10.609Y65.490
X10.336Y65.305
X9.841Y64.945
X9.346Y64.553
X8.856Y64.130
X8.407Y63.709
X7.963Y63.256
X7.738Y63.011
X7.338Y62.547
X7.129Y62.289
X6.752Y61.793
X6.396Y61.281
X6.050Y60.737
X5.885Y60.456
X5.592Y59.924
X5.301Y59.338
X5.052Y58.778
X4.926Y58.469
X4.712Y57.895
X4.510Y57.272
X4.346Y56.685
X4.200Y56.060
X4.082Y55.441
X3.990Y54.822
X3.954Y54.509
X3.901Y53.882
X3.884Y53.566
X3.870Y52.937
X3.884Y52.283
X3.923Y51.670
X3.989Y51.036
X4.035Y50.705
X4.138Y50.099
X4.266Y49.494
X4.344Y49.174
X4.510Y48.579
X4.715Y47.949
X4.929Y47.374
X5.049Y47.080
X5.307Y46.501
X5.585Y45.940
X5.893Y45.381
X6.211Y44.856
X6.387Y44.584
X6.747Y44.065
X7.127Y43.564
X7.336Y43.305
X7.749Y42.828
X8.186Y42.363
G0Z2.000
G0
G0
G1Z-0.711F39.0
X8.868Y41.710
X9.339Y41.304
X9.831Y40.914
X10.340Y40.543
X10.872Y40.190
X11.149Y40.018
X11.682Y39.711
X12.238Y39.420
X12.817Y39.147
X13.113Y39.019
X13.693Y38.790
X13.990Y38.682
X14.305Y38.577
X14.894Y38.399
X15.495Y38.244
X15.818Y38.172
X16.437Y38.054
X17.064Y37.961
X17.687Y37.896
X17.998Y37.873
X18.313Y37.856
X18.636Y37.846
X18.969Y37.843
X19.570Y37.855
X20.209Y37.895
X20.843Y37.961
X21.174Y38.007
X21.764Y38.107
X22.398Y38.241
X23.017Y38.400
X23.304Y38.483
X23.901Y38.677
X24.509Y38.903
X25.100Y39.152
X25.672Y39.422
X26.227Y39.712
X26.488Y39.859
X27.044Y40.196
X27.570Y40.546
X28.062Y40.904
X28.318Y41.102
X28.816Y41.514
X29.268Y41.920
X29.503Y42.145
X29.937Y42.589
X30.158Y42.828
X30.575Y43.311
X30.970Y43.809
X31.159Y44.065
X31.510Y44.569
X31.694Y44.852
X32.011Y45.376
X32.316Y45.930
X32.466Y46.225
X32.605Y46.513
X32.854Y47.073
X33.089Y47.667
X33.302Y48.277
X33.481Y48.870
X33.635Y49.468
X33.706Y49.787
X33.823Y50.398
X33.874Y50.719
X33.953Y51.343
X34.006Y51.969
X34.023Y52.285
X34.033Y52.608
X34.036Y52.942
X34.024Y53.542
X33.983Y54.192
X33.953Y54.509
X33.876Y55.120
X33.772Y55.736
X33.638Y56.370
X33.480Y56.985
X33.295Y57.595
X33.191Y57.902
X32.977Y58.477
X32.856Y58.773
X32.725Y59.074
X32.457Y59.644
X32.167Y60.199
X32.020Y60.460
X31.683Y61.016
X31.343Y61.528
X30.973Y62.038
X30.775Y62.292
X30.564Y62.553
X30.168Y63.012
X29.732Y63.476
X29.285Y63.915
X28.801Y64.350
X28.329Y64.740
X28.079Y64.934
X27.560Y65.312
X27.300Y65.489
X27.033Y65.661
X26.488Y65.992
X26.227Y66.139
X25.657Y66.437
X25.085Y66.706
X24.496Y66.953
X23.929Y67.164
X23.617Y67.269
X23.009Y67.453
X22.393Y67.611
X21.764Y67.744
X21.174Y67.844
X20.842Y67.890
X20.220Y67.955
X19.908Y67.978
X19.595Y67.995
X19.273Y68.005
X18.637
X18.313Y67.995
X17.998Y67.978
X17.689Y67.955
X17.071Y67.891
X16.437Y67.797
X15.822Y67.680
X15.508Y67.610
X14.894Y67.452
X14.599Y67.367
X14.005Y67.174
X13.397Y66.948
X12.808Y66.700
X12.254Y66.439
X11.956Y66.287
X11.404Y65.983
X11.134Y65.823
X10.609Y65.490
X10.336Y65.305
X9.841Y64.945
X9.346Y64.553
X8.856Y64.130
X8.407Y63.709
X7.963Y63.256
X7.738Y63.011
X7.338Y62.547
X7.129Y62.289
X6.752Y61.793
X6.396Y61.281
X6.050Y60.737
X5.885Y60.456
X5.592Y59.924
X5.301Y59.338
X5.052Y58.778
X4.926Y58.469
X4.712Y57.895
X4.510Y57.272
X4.346Y56.685
X4.200Y56.060
X4.082Y55.441
X3.990Y54.822
X3.954Y54.509
X3.901Y53.882
X3.884Y53.566
X3.870Y52.937
X3.884Y52.283
X3.923Y51.670
X3.989Y51.036
X4.035Y50.705
X4.138Y50.099
X4.266Y49.494
X4.344Y49.174
X4.510Y48.579
X4.715Y47.949
X4.929Y47.374
X5.049Y47.080
X5.307Y46.501
X5.585Y45.940
X5.893Y45.381
X6.211Y44.856
X6.387Y44.584
X6.747Y44.065
X7.127Y43.564
X7.336Y43.305
X7.749Y42.828
X8.186Y42.363
G0Z2.000
G0Z2.000
M5
M30
(END)
Haha, yes, and yo DID what I said (my mistake) but next time save it as a file.nc (or txt) file on your computer and upload the FILE here not the actual text.
FYI: 2 things. You know that your Z is off the thickness of the metal, right? I recommend NOT to use a metal gauge because it can cause micro cracking of the cutter (really). I recommend the use of Post it Note paper. It’s 0.004 inch or 0.1mm, Then after setting your Z0, move the tool off the material, lower the Z to Z0, then advance it the paper (or feeler gauge if I can’t talk you out of it) that thickness (NEVER onto the material, again it can damage the cutter). I guess if you were cutting something really soft you could lower it onto the material, but it is just bad practice.
Ok NOW I will look at your file…
Stock thickness = 0.25"
CC MAX depth = 0.028 (whichis about 1/32 inch)
If you are trying to cut this material all the way through, max depth should be (at least) 0.25 inch
Do you see the typo?
kdur
(Kim Durabb)
May 23, 2017, 2:16pm
#9
I’m open for any and all help so I will definitely use the post it paper.
OMG, so I think my mind was reversed. I thought the .028 was going deeper than the .025 so actually it should be either .025 or maybe .024 to be safe. Is that correct?
kdur
(Kim Durabb)
May 23, 2017, 2:34pm
#11
Ok, got it! My bad on the decimal mistake. I’ll make a new run now. Thank you so much for your help!!!
tito
(Bay Area and Sac, CA)
May 23, 2017, 8:42pm
#12
And the 0.028 is stepover, which is how much your end mill overlaps itself in the horizontal plane (at whatever depth the plane happens to be)–like drawing with a really thick magic marker, so thick that the edges of the lines overlap. The width of this overlap is the stepover.
kdur
(Kim Durabb)
May 23, 2017, 9:13pm
#13
Thank you! That makes sense now.
