I have 6 identical small lines that are to be pockets. The first and the fourth line will not create a toolpath for some reason. I have redraw them, copied them. I can’t figure it out. They are 0.062 inches by 6.0 inches long. I want to cut them 3.5mm deep. The bit size is 0.062 inches.
It’s so a certain degree, chance. The way the software strategy works is (as I understand it) create a grid the size of the tool, if the grid doesn’t land in the slot, it won’t be found.
