Hope you all had a great Thanksgiving! Quick question about the specific usb driver package that is installed with Carbide Motion. What exactly are they for? I’m having trouble using my usb from my Surface to my other machine (Nova 51 w/ Ruida controller). So I’m wondering if those specific drivers are doing something that might be causing issues on the Ruida?
Our drivers are not binary drivers that install additional code onto your machine. They’re just files that associate the built-in Microsoft drivers with our electronics. They’re very unlikely to cause a problem with other devices.
Figured out the problem. Nothing to do with C3D’s drivers or anything.
Maybe this might help others in the future. If you are using a laptop with a built in camera, you may have to disable it first in the device manager. Under your hardware and devices in control panel, set the usb camera as default imaging device. Then, under ‘camera’ in your control panel, give the usb camera rights to access apps. Bit of work to make it function, but happy I got it setup and doing its thing now.
