Please change the name of the contour file generated in the zip file at the end of the operation, when downloading the toolpaths. This is NOT a contour file, this is an etch file. As I recently found out after dragging a 1/8th end mill through my work after assuming the file name “contour” was going to cut out the contour of the board.
Contour is a common term in CNC, and it does not mean “etch”, “cut”, “drill”.
Please FTLOG change the name from contour, by default.
