Carbide Create 7 Pro
Gooday to All
Is there a way in CCv7Pro 2 set the default of “Snap to Grid” as the default to be “OFF” on startup of CCv7 Pro… I am sure someone knows how pull this off?.
TKS
Ken
No.
This isn’t even preserved as a per-file preference, so will need to be turned off each time a file is opened.
Great Question! It seems like common sense with most other graphic programs allowing it to be “off” as a default. I rarely use the grid function, if at all, requiring the useless step of unchecking it multiple times per session! There has got to be someone at Carbide stuck on grids!
A Hotkey would make this easier :wink:
While you’re at it, can we have an option (and hotkey) to toggle “Snap to node” ??
And maybe disable “snap to node” for objects on locked layers?
CC should have a Preferences dialog for things like this.
Tod1d/Will: Maybe this is something to suggest to the POWERS that be for possable change sometime also add a spell check to this site.?
Will when U were in the far east were U at NAHA and are U retaired AF 20 +? I have visited Okinawa USN 1960-1964
I was at Osan AB 1985–86, got out in 1989, not retired 'cause another 15 years seemed too long to young me.
