Hi all,
First program I want to run in CNCJS was a levelling / surfacing program…
Original .nc file was created in Carbide Create Pro 472. You can see the original Carbide Create file and gcode file here.
First few lines are as follows -
(Design File: /Users/michaelnewham/Google Drive (1)/1 FabLab_&_Hacker_Resources/1. Equipment/2. CNC_Machine - Shapoko, Files, Etc./Gcode Cut Files/Wasteboard_Levelling.c2d)
(stockMin:0.00mm, 0.00mm, -4.00mm)
(stockMax:804.00mm, 787.00mm, 0.00mm)
(STOCK/BLOCK,804.00, 787.00, 4.00,0.00, 0.00, 4.00)
G90
G21
(Move to safe Z to avoid workholding)
G53G0Z-5.000
(Wasteboard_Levelling)
M05
(TOOL/MILL,20.00, 0.00, 0.00, 0.00)
M6T101
M03S18000
(PREPOSITION FOR RAPID PLUNGE)
G0X390.00Y390.00
Z5.00
G1Z-0.64F50.0
Y397.00F2286.0
X414.00
Y390.00
X390.00
X380.00Y380.00
Y407.00
X424.00
Y380.00
X380.00
X370.00Y370.00
CNCJS is set-up, homing was done, work position was zeroed - then I pressed play on CNCJS. You can see from the pic below there was no response in the console. (I can manually, input code into the console and it works fine. I can start spindle remotely etc…)
Not too sure what I have to do as the program does not run. Is there another button to press? I did try ‘Cycle Start’ but nothing there either…
Files tried were .nc and the .gcode copy / equivalent. I had the files uploaded from the ‘watch folder’ sitting on the Raspberry Pi which CNCJS is installed on.
Any ideas to get this working?
Cheers, Michael
