Carbide Create freezes and not responding
I was having a problem with Carbide Create every once and a while where files won’t open. The program just freezes and I have to force close. I discovered a quick fix that I thought I would share with you all that works every time and maintains your custom tools.
  1. Copy your custom tools to your desktop (C:\Users\user name\AppData\Local\Carbide 3D\Carbide Create\tools)
  2. Delete entire CARBIDE 3D folder (C:\Users\user name\AppData\Local)
  3. Reinstall fresh copy of Carbide Create (https://carbide3d.com/carbidecreate/download/)
  4. Open and close Carbide 3D once
  5. Return your custom tools from your desktop to the tools folder (C:\Users\user name\AppData\Local\Carbide 3D\Carbide Create\tools)
THAT’S IT!
Now I’m wondering if I should setup a job to keep my tools synced. When I’m out and about I’ll layout a job on the laptop, on the machine shop computer when attending the Shapeoko. I’ve run into confusion a few times when looking for a tool that I added on one machine and not the other.
That’s all you have to do. Create all your tools on one computer, and then copy them to another :slight_smile:.
But mah scripts!! Automation. Breathes heavily.
Best thing is to put the file(s) on a network share which both computers mount and put shortcuts/aliases of them which Carbide Create will find/use from each computer.
