Carbide Create & G-Code - is there a way to specify starting point?
Happy Friday!
Is there a way to specify a starting point for a contour cut in Carbide Create? By default, my cut is starting in a less-than-ideal location, and if there was an option to choose a starting point, I would love to do so.
Carbide Create does not have a direct way to control this.
If you are cutting a contour which is closed you could cut the vector and edit it so that there was an overlap where you want the entry point.
