Carbide Create V5 won’t load, seems similar to what others have posted before as it’s a dead shortcut. Curerntly at 8 un/reinstalls. 2 Hard reboots, 2 safe mode reboots. Countless attempts to un/reinstall microsoft visuals. Command Prompt attempts as suggested in previous posts. And the event viewer is :
Description:
Faulting application name: carbidecreate.exe, version: 0.0.0.0, time stamp: 0x60479aec
Faulting module name: VCRUNTIME140.dll, version:
Someone recently had problems installing because they had a 32 bit Windows and the Carbide3d software seems to be 64 bit. You can check if you have a 32 bit OS or 64 bit OS. On Windows go into Settings, System, About and look at your System Type
Hi. Same issue here, I just got a new laptop with similar specs as the post above and I installed carbide create previously and it ran once and after a restart it wouldn’t open. It showed up in the task manager and hogged up my memory, then force quit itself and displays a log in the event viewer. I’ve searched around, but can’t find a solution. Did you manage to get it working?
Carbide had be create a new user with administrator privileges, install create there and run as administrator. It works that way. Literally nothing else helps nor was there any explanation other than call Microsoft. Hope it works for you.
The only caveat for “Run As Administrator” is you have to be be an administrator as well for our account. Most of our home laptops may only have one user so make sure you give yourself administrator privilege.
Go into Settings (Wn10) and Accounts and Your Info
