Fantastic — thanks, @Luke!
Especially appreciate the clarification that Bitsetter setup is CM only and isn’t sending/overwriting GRBL settings
@Luke Does Motion use the GRBL machine limits ($130 & $131) to calculate its rapid positions?
@neilferreri I don’t believe so.
@geoff - keep us posted.
First: thanks for all the help!
Second: I think your advice steps mostly worked. By deselecting HDZ and manually changing the recommended params (3, 102, 112,122, 132):
I’m guessing this is because CM jog controls ignore param 132 and instead just look at whether you have HDZ enabled in settings.
I can live with this for now, but would love others suggestions if you have them!
Best bet may be to remove my Suckit ears and try to find a different solution for dust collection. Given the popularity of the Suckit product, this feels like something to fix in a future version of CM: right now if you have an HDZ, as I understand it you need to choose between using a Suckit, or being able to jog through your full Z-range.
(Why is it a problem not being able to jog through the full z-range? well if I can’t jog to the spoil board, I can’t set it as my Z=0 to surface it)
We “might” have something to share in the next few weeks.
I was hoping something like that might be in the works
You sure know how to tease ![]()
