Carbide motion 521
Switching to fusion 5 tablet to run my shapeoko xxl with hdz. I downloaded carbide motion 521. I’ve noticed no option anymore for hdz with suckit dust boot. Will this crash or are all settings for it? Also I cannot jog z axis down past a certain point (1.5” above wasteboard). But it will go down measuring bit((bit setter). Any help would be appreciated
CM521 doesn’t enter the value for Z-axis under Travel Dimension correctly when using an HDZ — change that to 140 or 150 (or somewhere in-between, depending on your wasteboard setup).
Similarly, you can edit the X Travel Dimension after setting for an HDZ to make it match what your machine is actually limited to by the 3rd party dust shoe.
