Carbide Motion not seeing cutter
All at once carbide motion will not see the cutter I stopped in the middle of a project when I went to resume program says can’t find Cutter I tried new USB cable no lock tried different computer no luck upgraded software no luck. When I took the cover off of the circuit board I noticed that when I turn the power switch on the blue light comes on when I turn the power switch on or off but does not stay on not sure if it’s supposed to stay on continuously or not. Does anyone know if light supposed to be on continuously? I can hear and see reactions and movements when turning power switch on and off. Power source has power indicator light on.
Am a beginner.
Can I use a different Board? I am told none in stock and are on back order. As I am not very intelligent when it comes to this simple is what I need. I use Vcarve and motion for my projects.
I am dead in the water and need to get some things done.
Saw another post like this, the consensus was possibly the power supply. Unable to do a search right now to look for it.
Its not the power supply checked it. Its the board. Does anyone know if there is another board I can swap out.
