I just installed Mint on my new W11 laptop, no more windows for me. Hope a Linux version is coming soon.
From the post above:
Please let us know if it works for you in Mint or no.
I would definitely use a linux build, and I’ll test out and report back.
I also think it’s the only viable option if you guys ever thought about selling a tablet as an add-on to the printers. Linux is much easier on licensing, has better performance on lower spec hardware, and is much easier to tailor for a purpose built machine.
I have being using the Linux build of Carbide Motion on Linux Mint 22.1 for a few projects now and it’s worked great. Everything worked as expected (visualization, zeroing, tool changes, and running the job).
I am using a Shapeoko 3 XXL with HDZ, Bit Zero v1, and Bitsetter. PC is a Dell Optiplex 3050 micro PC with an i5-7500T, 8GB of RAM, 256GB SSD. Started with a 20" 1680x1050 monitor (in portrait orientation, so display was actually 1050x1680), this weekend I upgraded to a 15.6" 1920x1080 touchscreen monitor (in landscape). Carbide Motion performance is good, the UI is responsive and the touch controls are easy to use.
I would personally prefer AppImage for the distribution instead of FlatPak. I like the ease of a single download that you can run without any extra installation, and I also like the future proofing of being able to hold onto that download forever and it should just work. I primarily use AppImages for Linux applications when I can (LightBurn, gSender, Bambu Labs Studio, cncJS, etc).
Hopefully Carbide Create makes its way to Linux at some point too. I run CC through wine on my main desktop and the graphical/UI quirks of wine does leave a little to be desired (the limitations of the file open dialog being the most glaring deficiency).
Thanks for thinking of us Linux users!
Thanks so much for this flatpak! All the computers in my home, workshop and machine shop run Linux. I’ve been using a raspi 4 to run Carbide Motion, to control my Nomad 3 for several years. Now with this flatpak I am able to design and send jobs to my Nomad 3D from one computer. I run the latest version Linux Mint, and to run Carbide Create I use Bottles.
Cool, I didn’t know this existed (not being a Linux guy–yet–but just using Raspberry Pis at work to run stepper motors). Like portable Windows programs. No dependencies to satisfy. This would let me install CM on my CNC PC that is not allowed to contact the interwebs. I did some reading about AppImages and they seem to be distro-agnostic also which would be another plus. Thank you for mentioning it!
Thanks for this! It has been working well so far with initial testing on Ubuntu 25.10. Installation was smooth with @brbonline instructions. I hope that this is something that can continue to be supported long term!
I personally appreciate having an x86_64 Linux installer. But I can also see the use case where some appreciate being able to run on a Raspberry Pi. In general being able to run on older / less performant hardware would be ideal. If there could be a setting to disable the advanced 3D rendering based on hardware or user preference that seems like the most elegant solution. This would probably be appreciated by those without GPUs on other OS as well.
Found this interesting video on youtube. Take a look.
Thanks for releasing this flatpak.
It installed onto Ubuntu 24.04.03 LTS/ KDE desktop without problems, by following @brbonline instructions above to pull in the org.kde.Platform dependency. Everything seems to be working OK so far - we’ll see how it works with the new pendant when it arrives.
It’s running on a repurposed secondhand Lenovo ThinkCentre M900 mini-PC from Ebay - I run several of these as cheap rock-solid fanless servers around here for various tasks. With a cheap touchscreen added, it provides a simple solution for the workshop computing needs.
What specs do you prefer for the Lenovo?
It depends what I’m looking for (power vs cost). The I5-6500T Tiny with 16GB RAM and a 128GB SSD often go for around $75 (with Win 10 and the PSU) and they work just fine for these mini-server applications. For me, they’re the sweet spot. The SSD is simple to replace if you really need to do so. I have one as a DLNA server, one for my Home Assistant, etc. This one is also my Docker machine.
I’d prioritize the RAM size over the I5 vs. I7 or SSD size for these applications. It’s far easier to upgrade the SSD than the RAM in these devices, and an I5 is plenty of CPU.
My current one has built-in Wi-Fi, Ethernet, Bluetooth and either VGA or DisplayPort video out. A cheap display port to HDMI adapter cable ($6.50 from Amazon) and a USB cable for touch connects it to my monitor.
The new pendant arrived a couple of days ago. It also works fine on the Linux machine using this flatpak.
(By the way, although the Carbide Motion flatpak installed easily on Ubuntu (with the added steps above) or on Mint (flatpak already there, no extra steps needed), in neither case was the machine accessible to the software at first. I had to open up permissions to the associated serial port (/ttyACM0) to make that possible. I forgot to mention that above).
!! Where are you still getting PC’s still with Win10? It was past its freshness date last fall…
Ebay. And the Win10 is superfluous, since they are reimaged with Linux anyway. I actually just picked up another at that price to set up for a friend.
Oh, OK. I thought you might have found some obscure source of NOS Win10 PC’s… ![]()
Best deal I could find on eBay for a 16GB one was $99. I made a lower offer. Will see what happens.
Just received my pendant and found this thread while looking for a rpi build of Carbide Motion that would work with it. I currently run an rpi driving my HDM but would gladly upgrade to a regular linux box (which is what I had wanted to do from the beginning had it been available). Everything here is linux except for one isolated Win10 VM running SolidWorks. Everything is very stable except for one VM. I run Carbide Create Pro in linux using Crossover (essentially Wine) and would welcome a native version.
I have been trying to find a good deal on one of those Lenovo Thinkcentre boxes but the deals on eBay so for for a 16GB machine have been meh
I highly recommend getting a fanless N100 or N150 mini PC instead if you are going to have it near your CNC. I had a Thinkcentre in my living room for a media center PC and found that the fan got choked with dust and dog hair within a few months. I cannot imagine how quickly it would clog up near my CNC.
