Carbide Motion Router speed VS Carbide Create Router speed
Carbide Create has spindle speed for each bit. example 10,000rpm
Carbide Motion has a spindle speed of 24,000rpm.
Which RPM should I use - Carbide Create or Carbide Motion?
Thanks
Roger
I’m far from an expert on here but I use whatever CM stipulates I use based on bit selection.
The spindle speeds set in Carbide Create should be those requested in Carbide Motion.
Which version of Carbide Motion are you using?
Have you tried updating?
