Downloaded version 428
On my HP running Windows 7
Carbide motion will not open
States stopped working and closes.
Generally speaking an C000000005 error means CM tried to access some memory it didn’t own, or tried to access memory it once owned and no longer does…
BEX refers to a “Buffer Overflow”…
Something for the CM authors to look into.
Sorry, I know that didn’t help your issue at the moment.
Edit: This may happen because you are using Windows 7. You might want to back down to an earlier version of CM… Windows 7 is a bit old now and incompatibilities will only increase over time.
version 417 wont open either well this
sucks
Same error or different?
same error as the other version
