I have a Shapeoko machine on the way but also have a FoxAlien 4040XE and 3018 machine as well.
Is it possible to use Carbide Motion to control them all? If not can I use UGS which control my other Machines to control the Shapeoko when it arrives?
Carbide Motion only connects to machines w/ control boards sold by Carbide 3D.
Yes…
Do yourself a favor. When you received your new machine use Carbide Motion to get the machine set up and verify operation. After you get things running then use what ever you want
For initial setup it will make troubleshooting easier. If you have problems is it the machine or sender.
