I’m trying to set a work area of 9" Width (X) by 0.75" Height (Y). CC keeps setting my Height at 0.9843" after I input 0.75???
Thanks,
Sam
Thanks,
Sam
25mm is the minimum stock size in Carbide Create.
25MM=.984". So there is at least one work around. Make your stock the minimum allowed and then draw a rectangle your project size. Center the rectangle on the project material and use the center as your origin. Design your project inside the rectangle and you can fool the Shapeoko into working on a material that is smaller than allowed in CC. The key is to use the center of the project and keep your cutting inside your rectangle.
