Carving Speed Increase
I carved the Navy Emblem (6.625" x 6.625") using a 1/8" endmill clearing toolpath followed by a 60 degree 3 flute v-bit, the v-bit took 3 hours to carve, I use a 0.008" stepover, 0.050" depth 1st pass and a 0.015" second pass for a total depth of 0.065". my feedrate is 50 ipm and a spindle speed of 14,000 rpm. the carving turned out great but can I reduce the time without sacificing quality?
thanks,
David
Look at the basics:
and adjust based on your experience of the initial cuts and what you want in terms of surface finish and so forth.
Some discussion of this in:
