I made a CC file today and ran into a strange problem. When I saved as, and then tried to re-open the file, I can not see the design. The toolpaths are still there. And I can see a simulation of the gcode, but no design graphics. Is there a way to fix the file?
See if you can export the geometry as SVG?
I tried that. I was sort of able to export. By that I mean that I exported a file and opened it in InkScape. InkScape could find the line nodes, but no linework - I think InkScape calls the linework a stroke - I tried to change colors and fill but no luck.
Post the file here or send it in to support@carbide3d.com and we’ll do our best to work through this with you.
I just sent a file to Support.
