CC - Better handling of text alignment
Right now, if a text object is edited, the new text is place in the project with the same left edge as the previous text, and the same baseline, as the previous text.
If an alignment operation has been applied to the text field, I’d like that alignment to persist through edits. For example, if I center text relative to anything, then upon edit I’d like the new text to have the same center point as the old. This should occur for both X and Y, independently.
